My first suggestion is to move the Add Rows() up higher into the looping. Add Rows() is a pretty slow function, so if you could add all of the rows you need for the data table, to right after the initial New Table(), that would make the program much faster. That would also mean that you would have to add in an overall row counter, to keep track of what row you are working on, instead of using N Rows().
dt = Open(
"c:\users\txjim\documents\read in issue\example.xlsx"
Worksheets( "example" ),
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Worksheet Settings(
1,
Has Column Headers( 0 ),
Headers Start on Row( 1 ),
Data Starts on Row( 1 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 ),
Multiple Series Stack( 0 ),
Import Cell Colors( 0 ),
Limit Column Detect( 0 ),
Ymat = {};
For( i = 3, i <= N Col( dt ), i++,
If( Column( i )[1] != "",
Ymat = Ymat |/ Matrix( Num( Column( i )[1] ) )
dt << select rows( [1, 2, 3] );
dt << delete rows;
dt << delete column( 2 );
For( i = 1, i <= N Col( dt ), i++,
Column( dt, i ) << data type( numeric )
Xmat = Column( dt, 1 ) << get as matrix;
dt << delete column( 1 );
Zmat = dt << get as matrix;
dtFinal = New Table( "Converted", New Column( "X" ), New Column( "Y" ), New Column( "Z" ) );
dtFinal << add rows( N Rows( Xmat ) * N Rows( Ymat ) * N Rows( Zmat ) * N Cols( Zmat ) );
rowcnt = 0;
For( Xcnt = 1, Xcnt <= N Rows( Xmat ), Xcnt++,
For( Ycnt = 1, Ycnt <= N Rows( Ymat ), Ycnt++,
For( Zrowcnt = 1, Zrowcnt <= N Rows( Zmat ), Zrowcnt++,
For( Zcolcnt = 1, Zcolcnt <= N Cols( Zmat ), Zcolcnt++,
rowcnt++;
dtFinal:X[rowcnt] = Xmat[Xcnt];
dtFinal:Y[rowcnt] = Ymat[Ycnt];
dtFinal:Z[rowcnt] = Zmat[Zrowcnt, Zcolcnt];
dtFinal << Scatterplot 3D(
Y( :X, :Y, :Z ),
Frame3D(
Set Grab Handles( 0 ),
Set Walls( 1 ),
Set Rotation( -54, 0, 38 ),
Set Text Scale( 2 ),
Set Line Scale( 1 ),
Set Marker Transparency( 1 ),
Set Marker Quality( 0.25 ),
Set Marker Scale( 1 ),
Set View Perspective( 0.1 ),
Set View Zoom( 1 )
