ZY
ZY
Is there an easy way to get the FWHM of a normal distribution curve from Distribution function ?
Dear JMP community,
Is there an easy way to get the FWHM(full width at half maximum) of a normal distribution curve from Distribution function ?
ian_jmp
Level X
Re: Is there an easy way to get the FWHM of a normal distribution curve from Distribution function ?
Apparently, the FWHM of a Gaussian is about 2.355 * sigma. So once you have an estimate of sigma from the Gaussian fit you are done (use 'Analyse > Distribution' then go to the 'Continuous Fit > Normal' option from the red triangle).
ian_jmp
Level X
