Dear all,
thanks for the input. The reason why we need is "customer expectation", i.e. the addressee expects a certain way to calculate.
Meanwhile I found a way with a python workaround, see script below.
Thanks to all and best regards,
New Table( "Percentile_Cont_Example",
Add Rows( 7 ),
Compress File When Saved( 1 ),
New Table Variable( "SQL",
"with val_tab as
select 1 AS lot, 11.08 as value FROM dual
union select 1 AS lot, 12.76 as value FROM dual
union select 1 AS lot,10.85 as value FROM dual
union select 1 AS lot, 11.57 as value FROM dual
union SELECT 1 AS lot, 10.56 as value FROM dual
union select 1 AS lot, 12.27 as value FROM dual
union select 1 AS lot,11.81 as value FROM dual
SELECT
val_tab.lot
, val_tab.value
, percentile_cont(0.8) WITHIN GROUP (ORDER BY val_tab.value) OVER (PARTITION BY val_tab.lot) quant80_database
from
val_tab"
New Column( "LOT",
Numeric,
"Continuous",
Format( "Best", 12 ),
Set Values( [1, 1, 1, 1, 1, 1, 1] ),
Set Display Width( 60 )
New Column( "VALUE",
Numeric,
"Continuous",
Set Values( [10.56, 10.85, 11.08, 11.57, 11.81, 12.27, 12.76] ),
New Column( "QUANT80_DATABASE",
Numeric,
"Continuous",
Set Values(
[12.178000000000001, 12.178000000000001, 12.178000000000001,
12.178000000000001]
Set Display Width( 334 )
New Column( "Quantile80_JMP",
Numeric,
"Continuous",
Formula( Col Quantile( :VALUE, 0.80000000000000004 ) ),
Set Display Width( 141 )
New Column( "Quantile80_Python",
Numeric,
"Continuous",
Formula(
data = (As Column( :VALUE ) << get values)[
Loc( As Column( :LOT ) << get values, :LOT )];
Python Execute(
{data},
{result},
"import numpy as np
result = np.quantile(data, 0.8)
result;
Set Selected,
Set Display Width( 292 )
Georg
