  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Technician
Pass Command-Line Input Argument to OnOpen
I would like to select rows in a table based on command-line input parameter/arguments when opening *.jmp files. For example, in a Windows environment, I would like to run "$SAMPLE_DATA/Big Class.jmp 2 5 9" and have OnOpen script to retrieve the "2 5 9" arguments and interpret them to be a matrix [2, 5, 9] for an input to the "Set Select Rows" function. Any thoughts or alternative ideas would be greatly appreciated from the community.
ih
Super User (Alumni) ih
Re: Pass Command-Line Input Argument to OnOpen
I don't know of a way to get parameters sent to JMP directly, but two workarounds are:
  1. Use environment variables as demonstrated here:Jmp.exe arguments
  2. Call a batch file with arguments instead that saves those arguments to a file in a specific location and then opens JMP which reads that file.
frank_wang
Hi Technician
Hope below JSL can help you to solve the problem.
rows = dt << Get Rows( {2, 5, 9} );
心若止水
ih
