Check out the JMPĀ® Marketplace featured Capability Explorer add-in
wgardnerQS
Parsing << Get Estimates list elements
The below script is from one of the scripting index entries for the "Get Estimates" message. The object returned is a list. Are the individual elements of the list easily parsed? Type(estimate[n]), "Name". estimate[2], for example, appears to contain a consistent data structure. How does one return, for example, the matrix denoted "Time End"?
I know that all of the information output by "<< Get Estimates" is ultimately accessible via "<< Get Report" and deciphering the display box hierarchy. However, the concise and easily interpreted structure of "Get Estimates" looks like it could be easier to use and result in simpler code.
//scripting index script
dt = Open( "$SAMPLE_DATA/Reliability/Fan.jmp" );
obj = dt <<
Life Distribution(
	Y( :Time ),
	Censor( :Censor ),
	Fit Exponential,
	Set Scale( Exponential )
estimate = obj << Get Estimates;
Show( estimate );
//content of estimate[2]
nonparametric estimate(
	{Time Start(
		[450, 1150, 1150, 1600, 2070, 2070, 2080, 3100, 3450, 4600, 6100, 8750]
	), Time End(
		[1150, 1150, 1600, 2070, 2070, 2080, 3100, 3450, 4600, 6100, 8750, 11500]
	), Estimate(
		[0.0142857142857142, 0.0287815126050419, 0.0432773109243697,
		0.0579961215255332, 0.0751234647705236, 0.0922508080155139,
		0.109378151260504, 0.128327552297515, 0.147698051135348, 0.17276575551372,
		0.204582457224731, 0.292962184199761]
	), Standard Error(
		[0.0141833064113421, 0.0200581923902226, 0.024441823837429,
		0.0281508958436217, 0.0324334709625386, 0.0360727593407561,
		0.0392481174087784, 0.0427434474191106, 0.0459737153753552,
		0.0509999042262761, 0.0581216781767556, 0.098041976927893]
Re: Parsing << Get Estimates list elements
How do you wish to parse it? Is this information enough that you can use lists like this in JMP
estimate["nonparametric estimate"]["Time End"]
wgardnerQS
Works perfect.  Thank you!  Is that type of data structure documented?  I did not find it.
Lists do have quite a bit of documentation in Scripting Guide Scripting Guide > Data Structures > Lists in JSL Scripts . I think that behavior is also documented somewhere BUT it might not be under the lists section... I might have just gotten it by pure luck and trying out all sorts of things or I might have read about it (I will try to find it from documentation and will edit if I find it). @EvanMcCorkle
Edit: Found it mentioned at least here (I didn't find it from here first time I got it for sure, but it is mentioned) Scripting Guide > Data Structures > Lists in JSL Scripts > Subscripts in Lists
mmarchandFSLR
In this case, you could use this lovely script.
End = Arg( Arg( Arg( estimate[2], 1 ), 2 ), 1 );
mmarchandFSLR
Or use @jthi's much better one.
