Parametric survival analysis using right/left censoring
Feb 26, 2014 04:46 PM(8978 views)
Hi all,
Is there a way to perform parametric survival analysis using right/left censoring? The "Fit parametric survival" platform allows only one censor column, unlike non-parametric survival analysis. Thank you.
