Calculating difference between two dates and times in hours
Iam trying to subtract two dates and times and get the answer in hours. For example
     Column1                   Column2
01/30/2013 5:30       02/02/2013   14:30
I want to subtract column1 from column2 and the difference in hours. I want to do this in JSL Scripting language... Can some one help how to subtract the above two dates..I mean the formula for doing that,.
Thanks a lot
ms
Super User (Alumni) ms
Re: Calculating difference between two dates and times in hours
Same principle:
((:Column 4 + :Column 3) - (:Column 1 + :Column 2)) / 60 / 60
ms
The date/time value internally represents nr of seconds since a reference date. Simply substract the the columns and divide with 3600 to get the result in hours.
(:Column2-Column1)/60/60
But the Date is one column and Time is in another column. Sorry, I represented my data wrong in the above example. It actually looks like
  Column1           Column2               Column3                  Column4
here column1 and column 2 is one set . Example, jan 30th 5:30 AM is represented by column 1 and column 2.
Feb 2nd 14:30 PM is represented by column 3 and column 4. Now I want to know how many hours are in between Feb 2nd 14:30 PM and Jan 30 5:30 AM.
Thanks,
ms
Same principle:
