rohanmital
Parallel Plot - Lining Up Axes
Hi All,
Having some trouble in constructing a parallel plot, does anyone know of a way I can line up the 0-4 on the left axis with those on the right? I would like to retain the thick lines if possible, the data in these columns is currently labeled as Character - Ordinal. I was able to merge axes as numerical columns however this loses the thick lines. Is there any solution to this? Any help is greatly appreciated!
Phil_Kay
Re: Parallel Plot - Lining Up Axes
I don't think it will be possible align these: the positioning of the categories on the Y-axis is dependent on the number of observations in each category. And I don't think there is any way to manually edit the axis settings for a parallel plot. You might like to request this on The JMP Wish List.
hogi
Level XIII
really disappointing that this is not possible in JMP.
I have the same issue - and posted a wish:
Parallel Plot: synchronized axes
