Hi @DI !
Looking at your situations and explanations, you have :
- 3 groups : 0, 1 and 2 days,
- Same samples for the three groups, since replicates come from the same original sample.
I would go for a Friedman test, which is a non-parametric paired test for more than two groups. You have your (source/original) sample ID as a blocking factor, and Time/days as your grouping variable (see example attached).
If you consider your different replicates are independent (not coming from the same sample source), then a Kruskall-Wallis test might be appropriate.
More infos here : Nonparametric Tests (jmp.com)
I'm sure statistical experts in this community will have other ideas or questions for you to help you.
I hope this first answer will help you,
Victor GUILLER
Data & Analytics
