Djtjhin
Button to open specific outline in a journal
Is there a way to add button in a journal that opens a specific outline within the journal ? (e.g. similar to in-document referencing in word documents)
I've seen journals used <<open next outline, but I believe this  won't be able to open outline box if it's not positioned right next to the containing outline box.
Re: Button to open specific outline in a journal
Maybe you can use something like this:
Current Journal()[OutlineBox("Outline3")] << Close(0)
Djtjhin
@jthi  Yeah, I was using xml and was able to get it to work :)
Now I wonder if there's a way to bring the opened outline to the top of the page. Any ideas on this ?
Not sure if you can move display element, but you could maybe remove and then re-add it
New Window("WrapListBox",
	vlb = V List Box(
		ob1 = Outline Box("1"),
		ob2 = Outline Box("2"),
		ob3 = Outline Box("3"),
wait(1);
ob_to_move = Remove From(vlb, Contains(vlb << XPath("//OutlineBox"), ob3));
wait(1);
Insert Into(vlb, ob_to_move, 1);
Another way of handling this, is to completely hide the outline box of interest, rather than closing it;  The button box can then redisplay the outline box, rather than opening it.  This is all done using the Visibility element available to the Outline Box() object.
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "/C:/Program Files/SAS/JMPEA/17/Samples/Data/Big Class.jmp" );
ow = Oneway(
	Y( :height ),
	X( :age ),
	Means( 1 ),
	Box Plots( 1 ),
	Mean Diamonds( 1 )
nw = New Window( "My Display",
	<<journal,
	bb = Button Box( "Display Anova",
		nw["Oneway Anova"] << visibility( switch );
		If( switch == "visible",
			switch = "collapse";
			bb << set button name( "Hide Anova" );
			switch = "visible";
			bb << set button name( "Display Anova" );
Report( ow ) << journal;
ow << close window;
switch = "visible";
nw["Oneway Anova"] << visibility( "collapse" );
