Overwrite data in a table
LGaspard
I am trying to clean up my data table. I have a table with some value which are "x", "X", "X-Direction", "X-direction", but they are all the same, which is "X".
How can I change the values (in the script) so it overwrite everything with the same format ("X")?
Because then, I want to split my data table and it gives me 4 columns where I should have only 1... Thanks!
Re: Overwrite data in a table
One option is to use Recode:
Select your values you wish to recode
Press Group
Select how you wish to recode them
And finally press Recode
Changed this:
to this
And if you have JMP16+ you can get the code from action recorder
// Recode column: Column 6
Local({dt},
	dt = Data Table("Big Class");
	dt << Begin Data Update;
	dt << Recode Column(
		dt:Column 6,
		{Map Value(
			_rcOrig,
			{"X-Direction", "X", "X-direction", "X", "x", "X"},
			Unmatched(_rcNow)
		Update Properties(1),
		Target Column(:Column 6)
	dt << End Data Update;
Or from Recode menu before you press Recode
Press Group
Changed this:
to this
Local({dt},
		dt:Column 6,
		{Map Value(
			_rcOrig,
			Unmatched(_rcNow)
LGaspard
It works!! Thanks :))
