mrq
mrq
Overlay different plot type for different data set
I want to have a scatter plot for dataset 1 and line plot for dataset 2 in a single plot or graph builder. It is more like the way we can change the plot type for different dataset in excel, when both dataset are plotted in a single graph. Any idea how to do that in graph builder
Re: Overlay different plot type for different data set
JMP Platforms (i.e. Graph Builder) requires that all data that is going to be plotted has to be in a single data table or in virtually linked data tables.
ZF
ZF
Have you tried copy and paste frame contents while both are plotted in separate graph builder?
You can have more than one variable in the Y or X role. Right-click on the axis and select Move to place one of the variables on the opposite side. Then right-click in the plot frame and independently change the plotting elements for each of the variables.
