MFellermann
“Out of spec rate” calculation
Dear JMP community,
How is the “Out of spec rate” calculated in JMP (see image below)? The tool can be found in the evaluation of Ppk and Cpk values.
In JMP there are no formulas provided for the “Out of spec rate” calculation.
Is this based on an assumed normal distribution and the spec limits?
Thank you in advance.
Best regards
Maximilian
Re: “Out of spec rate” calculation
Most likely the normal calculations when you wish to calculate the probability that a normally distributed value is greater/less than (or both) than a specific value when you have known normal distribution.
Quality and Process Methods > Process Screening > The Process Screening Report
Out of Spec Rate
The proportion of observations that fall outside the specification limits. On by default.
MFellermann
Thank you for the quick reply and your help. Does the program assume a normal distribution for calculating the proportions?
I'm pretty sure that is calculated from your data. Expected Out of Spec rate uses different calculation and makes some assumptions on your data.
MFellermann
Thanks again Jarmo.
This is quite helpful. Do you know, where I can find the formula how the “Expected Out of Spec rate” is calculated?
BR,
Maximlian
