Martin here.
Need some help with profiler.
It is a three factors custom design.
factor #1: Blue circle cement (0.6898~0.7431)
factor #2: Ternal white cement (0.2546~0.3009)
factor #3: sodium citrate (retarder) (0.0023~0.0093)
it is a cementitious formulation. one of the most important reponse is adhesion after water immersion. I want to optimize the adhesion, it needs to be above 1MPa.
Below is the profiler generated by JMP with maximizing desirability. adhesion after water immersion is 0.98 MPa which is not good enough to meet 1 MPa.
![JMP #1.PNG JMP #1.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6817i7DBADE84756539CF/image-size/large?v=v2&px=999)
By manully change the propotion of three factors, profiler show below results, with adhesion after water immersion around 1.02 MPa.
![JMP#2.PNG JMP#2.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6818i93AF06635F4B88C4/image-size/large?v=v2&px=999)
So my question is what is the procedure of optimization with profiler? Do we relay on desirability function or we have to manully adjust the level of factors?
what if the desirability function fails to meet the target?
Regards
Martin
