msharp
Opposite of Default Local
So, just some syntactical sugar.
It would be really nice if there was an opposite of declaring local variables for functions.
i.e. instead of:
example= function({a,b}, {c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w},
       c = a+b;
       d = c+a;
       x = v+w;
       y = x+b;
print(x,y);
I could write:
example= function({a,b}, {Default Local, x, y},
       c = a+b;
       d = c+a;
       x = v+w;
       y = x+b;
print(x,y);
msharp
Re: Opposite of Default Local
Another example:
x="global scope";
y="global scope";
Names Default to Here(1);
x="here scope";
y="here scope";
print(::x, x, ::y, y);
f = function({}, {Default Local, x},
       x="here scope replaced";
       y="function scope";
       print(x, y);
f();
//x != y but it does
print(x, y);
Phil_Brown
I think if you scope everything, you may get what you want.. Correct me if I'm not following but....For instance
::x="global scope";
::y="global scope";
x="here scope";
y="here scope";
print(::x, here:x, ::y, here:y);
f = function({}, {Default Local},
       here:x="here scope replaced";
       ::x = "global scope replaced";
       x = "function scope x";
       y = "function scope y";
       print(here:x, ::x, x,  y);
f();
print(x, y); // will be whatever was assigned to these vars in the HERE namespace.
print(::x, ::y); // will be whatever was assigned to these vars in the GLOBAL namespace.
// no way of accessing local vars (actually the point of local).
PDB
I've been using explicit locals in functions.  I think I'll try Default Local in my next project.
msharp
I've never used here:x before, but that syntax makes total sense.  Thanks!
vince_faller
Same goes with local:x if you'd rather explicitly scope on the fly.
f = function({}, {},
       local:x = "function scope x";
       local:y = "function scope y";
       print(::x, local:x,  y);
f();
You have to remember to call ::x explicitly because of the scoping rules for unscoped variables.
Vince Faller - Predictum
