Operating on selected rows
Hello Everyone,
Is it possible for me to operate a function on selected rows without using the FOR loop.
For example
k = dt<< Get Rows Where (pt:Parameter = ot:Parameter);
For (i=1,i<= Nrow(k),i++,
pt:value[k] = pt:value[k]/5;   // I want the value of selected rows only to be divided by 5.
Is it possible for me to rewrite the code without using simple JMP function for it ? I dont like using too many for loops.
Thanks in advance!
regards,
Akash
6 REPLIES 6
ian_jmp
Level X
Re: Operating on selected rows
NamesDefaultToHere(1);
Wait(3);
k = dt << getRowsWhere(:sex == "M");
h = Column(dt, "height") << getValues;
h[k] = h[k]*0.5;
Column(dt, "height") << setValues(h);
anders_bankefor
Hi Ian,
what does "Wait(3);" do in this context?
BR
Anders
ian_jmp
Level X
It causes JMP to pause for 3 seconds, and I inserted it so that you could see what's happening (run the code and look at the column called 'sex'). You can remove it of course.
ms
Super User (Alumni) ms
Or try the "Divide To" assignment:
dt:height[k] /= 5
David_Burnham
Just curious, why don't you like using loops?
-Dave
Thanks for replies.
Just that i deal with huge amounts of data and running loops for every action increase the processing time. I hope inbuilt functions/operators will be more optimized than me writing loops.
