_Mel
Opening JMP Home Window opens other windows
Has any had an issue where they open the JMP Home Windows and it opens other graphs and data tables, and runs scripts you created ages ago? The most odd thing being most of what is opening I have deleted from my computer (graphs, data table, and scripts).
I've tried uninstalling and installing JMP, as well as rebooting my computer a million times. Any help is appreciated!
Re: Opening JMP Home Window opens other windows
Did you save a 'session script?'
_Mel
@Mark_Bailey
I was unsure what a session script was before you posed the question. I did some reading on it, and this seems to be what is causing the windows to open up. I can't find a way to delete these or stop them from happening. Do you know how to stop sessions scripts from occurring when I open JMP?
See this Help.
_Mel
@Mark_Bailey
Thank you for your help! It turns out that a session script was saved to one of my data tables. As soon as I renamed it, JMP stopped running the previously deleted script.
