shampton82
Level VIII
Number of elements in the tree structure
Okay, this is probably another easy one but stumped once again.  How do I determine how many boxes are in an analysis' tree?  I want to loop through the boxes to get values but don't see something I can return and then use with n items() or <=Variable in the for loop.  Also, is there a way to find the number of a specific type of box (such as col list box only)
Thanks for any suggestions.
Steve
Re: Number of elements in the tree structure
You can use Xpath() for those kind of questions.  Xpath is a language that interrogates xml, which is actually the base of the Tree Structure in JSL.
Xpath is an independent language.  You can search the internet for training for it, if you want to really use it.
Here is a simple example of finding the number of TextBoxes in a Display Tree.
//This message applies to all display box objects
win = New Window( "test", Text Box( "my test" ) , text box("aaa"));
count=nitems(win << xpath( "//TextBox" ));
