  • See how to interactively organize and restructure data for analysis. Register for May 29 webinar, 2pm US ET.
shampton82
Get the title from a number col box
Okay so just starting to dive into Tree navigation and I have this simple script that I'm experimenting with:
names default to here(1);
dt=current data table();
//this is a partition analysis
actobj=Current Report()[outlinebox(1)]<<get scriptable object;
actobjrpt=actobj<<report;
//this links to the Logworth value from the first split
actobjtable = actobjrpt[numbercolbox( 7 )][1];
So I can get the value of the Logworth but I also want to get the title from the numbercolbox which is "Logworth".  So far I can't figure it out.  Thanks for any suggestions!
Steve
Re: Get the title from a number col box
Here is one way to get what you want
// Open Data Table: big class.jmp
// → Data Table( "big class" )
dt = Open( "/C:/Program Files/SAS/JMPPRO/14/Samples/Data/big class.jmp" );
Partition(
	Y( :height ),
	X( :age, :sex, :weight ),
	Informative Missing( 1 ),
	Initial Splits( :weight < 81, {}, {:age == {12, 13}} ),
		Dispatch( {}, "Partition Report", FrameBox, {Frame Size( 480, 62 )} )
actobjrpt=Current Report();
actobjtable = (actobjrpt[numbercolbox( 7 )]<<get)[1];
// get the header
theHeader = actobjtable = actobjrpt[numbercolbox( 7 )]<<get heading;
show(actobjtable, theHeader);
Partition(
	Y( :height ),
// get the header
shampton82
I was so close! I tried "Get" and "Get Title" then gave up and came here as there are a million get commands.
Thanks for the quick rely!
Steve
Craige_Hales
see if the <<GetHeading message is the one you need.
Scripting index example for Get Heading.Scripting index example for Get Heading.
Craige
