dnh234589
Normalize a column
TLDR: How do I normalize a column to itself?
See attached. I have:
  • Column A = 0,1,2,3. Maybe think of this as like an ID number
  • Column B. Think of this as a timestamp
  • Column C. This is the data
Now I want column D to have the data in Column C, ONLY when B=1.
As you can see in the attached file, I have manually copy-pasted the yellow cells from C into D. Pasted over and over.
Therefore when I do D/C, I'm basically normalizing the whole of column C, to these special yellow values. This is the reason I'm doing all this, is to find D/C. So a value of 0.9 in this column means C is lower than the yellow C's, and 1.1 means it's higher than the yellow C's.
So, long story short, what is the formula that goes in D, to be able to get the yellow values?
Level XIII
Re: Normalize a column
Use a grouped Col aggregation like col Median() to define the values of column D as
Col median(if (:B==1,:C), :A)
You can also skip Column D and directly calculate :C/Denominator.
There is an AddIn in the Marketplace which does such Normalization automatically.
11 REPLIES 11
mmarchandFSLR
edit
Sorry, I need to pay more attention.  You weren't asking how to get D/C.
Select C and D, then right click.  New Formula Column > Combine > Ratio (reverse order)
mmarchandFSLR
Sorry if I'm still misunderstanding, but if you want D to be missing when B is not 1 and D to have the values of C when B is one, try this formula.
Choose( :B, :C, . )
dnh234589
Thanks for your answer. Not exactly. I simply want a formula in column D, that will reproduce those numbers.
That formula will take the yellow cells in C, and apply it to the entire column D. So that now the entire column D is the repeated yellow cells as shown. (Presumably in the formula somewhere, we would hardcode B=1.)
Probably I confused things by manually typing in D in the example. I manually typed in those numbers, but I want a formula that will populate D for me.
dnh234589
Thanks for your answer, but here is a comparison of your answer, and what I want which is just a formula for D. So compare the final column and D and you'll see they are not the same.
Isn'1 the formula just
If( :B == 1, 1, :D / :C )
dnh234589
No, I want to find the formula for D. In my example I just manually typed in the numbers for D but I want a formula
Level XIII
what is wrong with
I'm sure there is a way to script a solution, but I would instead propose that switching from your Tall data format to a Wide data format makes more sense in this case. When using JMP formulas, it is always easiest when all the terms needed for that calculation are in the same row. (Sometimes this is impossible, then clever scripting is needed. But in this case, it is possible.)
My suggestion: Split the data table so that it is in a Wide format, with a separate Column for each "B". Then normalizing (diving by C) becomes easy.
You can recode the column names to make them a bit more readable:
After adding the new formula columns, you end up with:
Would this work for you? I attached the table for your reference.
Level XIII
