tylerg4
Non-parametric Mixed Model
Hi everyone,
New to the forum.  I've been using JMP for a while now and I have encountered my first problem.  Maybe it's not a problem to any of you, but I don't know how to run a non-parametric test on a mixed model.  My understanding through the fit model platform is that this is a parametric method.  However, there is no way to transform my data.  I have a response, y, a fixed factor, and a random factor.  Any advice would be appreciated.
Thanks,
Tyler
Phil_Kay
Re: Non-parametric Mixed Model
Hi Tyler. I'm not clear what you are trying to do. What is the non-parametric test that you want to run? Also what transformation of your data do you need?
Regards,
Phil
