adjgiulio
Non Parametric density
When I generate a bivariate plot and then request the Non Parametric density, how do I go about getting percentiles back into my data table, based on the quantile density contours?
I’d like to add one column to my input table that would tell me, for each observation, in which contour it falls.
Thanks,
G
mpb
mpb
Re: Non Parametric density
The density plot has a red triangle pull down menu associated with it which contains a choice to "Save Density Quantile".
pliddi
What if you're not using the bivariate plot?
If using the 'nonpar density' option in 'scatterplot matrix', how does one save the data or alter the contours?
This would be extremely useful because you can specify multiple Y variables and no specific X regressor.
Honestly, I am desperately seeking an answer to this...
Regards,
Peter
