gbu
gbu
Catching database error message
I would like to know if there is a way to catch database error message and put it into one jmp variable.
Example for an Oracle DB, if I try to insert one value already existing on ID primary key :
/* JSL */
sql = "INSERT INTO MY.TABLE (ID, DATA) VALUES ('A',150)";
OpenDatabase (dsnDB, sql);
/* LOG display */
[Oracle][ODBC][Ora]ORA-00001: unique constraint (MY.TABLE) violated
ORA-06512: at line 1
I would like to have in a jsl variable this sting : "[Oracle][ODBC][Ora]ORA-00001: unique constraint (MY.TABLE) violated".
I didn't find any solutions for the moment.
Thanks.
stan_koprowski
Re: Catching database error message
One way to do this is with the Log Capture function. To test the JSL code I simulated two different types of errors:
  1. A failure error by not establishing a connection to the Access database prior to selecting the columns from the specified table
  2. A failure error by not having an appropriate ODBC driver installed
I have included an example of how you could accomplish what you want to do in the following JSL code and the resulting error messages:
AccessError01 = "Access Error:" || Log Capture(Open Database(
"DSN=MS Access Database;DBQ=C:UsersstkoprDocumentsMovinOn.accdb;DriverId=25;FIL=MS Access;MaxBufferSize=2048;PageTimeout=5;UID=admin;",
"SELECT * FROM tblVehicle",
"tblVehicle"
The following is written to the log and the error string is stored in the variable AccessError01 for scenario test 1.
"Access Error:
[Microsoft][ODBC Microsoft Access Driver] Could not find file '(unknown)'.
The following is written to the log and the string is stored in the variable AccessError01 for scenario test 2.
"Access Error:
[iODBC][Driver Manager]Data source name not found and no default driver specified. Driver could not be loaded
Yes, you can...connect to an ODBC database
stan_koprowski
"tblVehicle"
"Access Error:
"Access Error:
gbu
gbu
Thanks for this great tips. Log Capture function is the function that I was looking for.
