Dear community,
I am trying to use the prediction profiler with one of the factors having the nominal data type. In the example below, the Factor 1 can assume two values, “One” and “Two”. The formula to be profiled contains a ‘Match’ statement that selects the numerical value 1 or 2, according to which string (“One” or “Two”) is entered, see the example code:
dt = New Table("Simulate",
Add Rows( 1 ),
New Column("Factor 1",
Character,
"Nominal",
Set Values({"One"})
New Column("Factor 2",
Numeric,
"Continuous",
Format("Best", 12),
Set Values([3])
New Column("Response",
Numeric,
"Continuous",
Format("Best", 12),
Formula(Match( :Factor 1, "One", 1, "Two", 2 ) * :Factor 2)
Profiler(
Y(:Response),
Simulator(
Factors(
Factor 2 << Random( Normal( 3, 0.1 ) )
When I run this code, a profiler report opens, like the one shown.
Now, here is my question: How do I get the dropdown menu below the graph for Factor 1 to show both options “One” and “Two”? The profiler and the simulation result should then change, according to which string value is chosen for Factor 1.
Any help is much appreciated.
