Lavik17
No local filtering in project on macOS ?
Hi all,
I'm using JMP 17 on MacOS, and when I use the graph builder within a JMP project I don't see the local filter icon that is usually there outside of project. Is this intentional or am I missing something?
Re: No local filtering in project on macOS ?
Are you referring to the icon for the Local Data Filter in the toolbar area?  Projects have different default toolbars because the window handles multiple document types, but you can configure the icons that appear in this area:
Both inside and outside projects, you can also activate the Local Data Filter from the red-triangle menu for a platform:
Hope that helps,
-Dan
Hope that helps,
-Dan
Lavik17
Thank you Dan!
I expecting the icon to appear in the bar from a UI consistency point of view...
