zetaVagabond1
No Module named 'pandas'
I’m running a JSL script in JMP 18 that uses Python. On macOS everything works fine, but on Windows I get this error:
Traceback (most recent call last):
  File "<string>", line 7, in <module>
ModuleNotFoundError: No module named 'pandas'
In the embedded log is see following:
Creating: C:\\Users\\Admin\\AppData\\Roaming\\JMP\\JMP\\Python\\Python311\\site-packages
This tells me that JMP 18 doesn't install python automatically. Is there a pre-requisite for python be installed?
I am also trying to install this way to ensure the script doesn't fail irrespective of the system:
Python Submit("
import jmputils
required_packages = ['pandas', 'numpy']
# get list of installed python packages
installed = jmputils.jpip('list')
# check & install missing packages
for pkg in required_packages:
    if pkg.lower() not in [p.lower() for p in installed]:
        print(f'{pkg} not installed — installing...')
        jmputils.jpip('install', pkg)
    else:
        print(f'{pkg} is already installed.')
Re: No Module named 'pandas'
To my knowledge, in JMP18 that folder gets added when Python is "run" first time and you can most maybe force it by running something like
Python Submit("import jmp");
in JMP Script Editor
Level XIII
An error message from Python is a clear sign that python is installed ; )
to install Python packages from JSL, please use:
Python Install Packages( "numpy pandas" );
zetaVagabond1
Thanks, yes it created the python directory and few packages. below:
Python Submit("
import jmputils
required = ['pandas', 'numpy']
# Get installed packages safely
if installed is None:
    installed = []
print('Installed packages:', installed)
# Install missing ones
for pkg in required:
    else:
        print(f'{pkg} already installed.')
import pandas as pd
import numpy as np
print('pandas and numpy imported successfully!')
zetaVagabond1
yes, that did help me to ensure the folder gets added. thanks
Using that import is one of the checks we use in our JMP-Python applications to make sure everything has been setup.
I'm still holding out from using JMP19 due to many reasons, but it will make using JMP-Python integration easier. If I remember correctly in JMP19 it will be unnecessary, but I haven't verified it. JMP19 will also make it easier to check if packages have been installed as jmputils gets "is_installed" method.
In JMP 18, unpacking the site-packages.zip file and creation of the directory was done by the jsite.py script. JMP 19 does this internally in C++ code the first time Python is initiated.   The jsite.py script still exists as a backup for when the command line jpip.bat or jpip shell scripts are generated by Python Create JPIP CMD(). Or it's Python equivalent jmputils.create_jpip( dest_path ) .
JMP 19 improves scriptable package management by adding jmputils.is_installed( 'package_name' ), jmptuils.package_version( 'package_name' ) and pkg_dict = jmputils.packages().  These were late additions to 19.0, they are present, but not documented in the scripting index.  Later updates do have examples in the scripting index.
