Effluvium
Newb question
Hello everyone,
I use the chart builder in JMP.
From the columns of my database, I create measures (indicators) directly in the chart builder to display them.
For example with my column A and my column B, I create the measure with the formula AB.
This measurement refers to an indicator that I add to my graph just below the title.
The problem is that I would like to give a color to the measure I create based on the value of that measure.
I would like to be able to put the text in green if the measurement is > 0 and put the text in red if the measurement is < 0.
For the moment, I can associate a color with the measurement but the color is not dynamic it does not change depending on the values.
Is there a way to get around this problem?
Re: Newb question
Which "chart builder" are you using, Graph Builder? Which text you wish to color?
Re: Newb question
And, assuming you used Graph Builder, did you use the subtitle?
