Jeff383
Using Column Properties sigma for control chart test
In past versions of JMP and with the legacy control charts, the sigma in column properties would apply to the test.  I specifically use Test 5.  This does not appear to be true for any of the new control charts in JMP18.  Is there a way to set the sigma for the control chart test?
Thanks in advance
Jeff
Re: Using Column Properties sigma for control chart test
I would guess it should still be used  Using JMP > Set JMP Column Properties > Column Properties in JMP > Properties Associated with Contr... but it doesn't seem to be the case. Maybe it is being overwritten by the "Set Sigma" option which was added in JMP18 when it should be other way around (column property should overwrite that). I would suggest you contact JMP support with email.
