pmroz
New Dynamic Linking Connections
One of the great features of JMP is the dynamic linking between objects. However, if you make a tabulation (B) from a table (A), and then convert the tabulation to a table (C), any connection between the original table (A) and (C) is lost.
Is there a way to add dynamic linking to connect two tables?
Thanks,
Peter
Re: New Dynamic Linking Connections
I'm pretty sure Tabulate won't link tables. I would recommend using Table --> Summary for that.
chungwei
Staff (Retired)
Tabulate does link the report to the source table. If you click on any data cell in the tabulate output, the relevant rows in the source data table will be selected.
