Jaz
Jaz
Nested if Statement
I just want to make sure that the following nested if statement will function correctly. At the moment I'm getting an error so I thought it might be to do with the way I constructed my nested if statement:
If (ismissing(dt:newColumnName[k]), For Each Row(If(dt:colAutomatically <= colManually[k] & dt:colAutomatically >= colManuallyStart[k], dt:newColumnName = colInstructions[k], dt: newColumnName = colInstructions[k-1] || " & " || colInstructions[k]));
The if statement conidtion is:
If this is true I want the following statement to run:
If this is false I want the following statement to run:
Any help would be appreciated.
Re: Nested if Statement
The expression to be evaluated if the first argument evaluated to false was inside the For Each Row() function. This code structure should do what you want:
If( Is Missing( dt:newColumnName[k] ),
	For Each Row(
		If( dt:colAutomatically <= colManually[k] & dt:colAutomatically >= colManuallyStart[k],
	dt:newColumnName = colInstructions[k - 1] || " & " || colInstructions[k]
Jaz
Jaz
Thanks for your reply but I want the following statement:
dt:newColumnName = colInstructions[k - 1] || " & " || colInstructions[k];
to be inside the loop.
Is there any way around that?
