johnj_wang1
Need the Add-in JSL script to plot wafer map.
Dear Sir or Ma'am,
Could you please get the Add-in JSL (JMP script) to construct the wafer map based on the value of each X/Y cell (either “0” Red or”1” green) for me?
I have already had the X and Y coordinate and Value of each test- either 1 (Pass) or 0 (Fail).
Thanks,
John
@MikeD_Anderson
Re: Need the Add-in JSL script to plot wafer map.
Hey!  If you stack your data so that the different tests are in one column and the result in a second (Test and Bin in the attached data table).  You can use the Semiconductor toolkit to generate these figures:
using these settings:
In the Patterned Wafer Map Tool
Best,
M
johnj_wang1
Hi Mike,
Great.  Would you please provide me a link to download the link to Semiconductor toolkit?
Thanks,
John Wang
Someone put it in an earlier comment.  And it's in the file exchange part of the community in the add-in's section.  It's one of the featured add-ins.
M
