johnj_wang1
Please email me the link to download "Semiconductor Toolkit_JMP14-15.jmpaddin" and the Semiconductor Toolkit_JMP14-15.jmpaddin script.
Hi Mike,
I am not able to download the Semiconductor Toolkit_JMP14-15.jmpaddin JSL.  It may have something to do with the security Fire Wall.
Would you please email the Semiconductor Toolkit_JMP14-15.jmpaddin JSL to me at [email protected].
Thanks,
John Wang
@MikeD_Anderson
Re: Please email me the link to download "Semiconductor Toolkit_JMP14-15.jmpaddin" and the Semiconductor Toolkit_JMP14-15.jmpaddin script.
Hey!  Since you're probably running into firewall issues, it's probably best not to try and do an end-run around them.  I'd work with your IT department to see what the issue is so that you can download it through the community.  In the meantime - you might have a look at this blog post that shows how to get similar functionality using Graph Builder: https://community.jmp.com/t5/JMPer-Cable/How-to-make-a-wafer-map-in-JMP-in-under-30-seconds/ba-p/348...
Since graph builder is a native part of JMP, you already have it and the workflow I show in the blog article should still work in JMP 15.
Best,
M
