wjalford
Need help with select where date.
I am creating a subset where I am using Select Where :Login Date == 01/18/2019;  I cannot get it to work.  I also tried opening the subset and running the query builder.  I can add all of the fields and then filter by login date.  The login dates show in the filter.  If I choose one of the dates and hit update, no records show.  Below is my code and I have attached the screen shot of the query builder.  Any help would be appreciated.
Regards,
Wayne
Re: Need help with select where date.
The issue is that you have :login Date as a character column, and it contains the time data along with the date data.  So when you compare it to ALstartDT, it is having issues.  I suggest that you uncomment the line where you attempted to change the :Login Date to a numeric with a format of "m/d/y".  It should slightly changed to look like
dt6:Login Date << data type(numeric) << modeling type(continuous)<< format( "m/d/y");
and then change your select where lines to
dt6 << Select where ((Contains(MyList, :Site ID)) & :Analysis == "G4");
dt6 << Select where (:Login Date >= informat(ALstartDT,"mm/dd/yyyy"),current selection("extend"));
18 REPLIES 18
JMP Date values are numeric values.  If you wanted to compare a value in "Login Date" to a date value, you either need to convert the value of "Login Date" to a character string and compre it to "01/07/2018", or keep it as a numeric and convert "01/07/2018" to a date time numeric value.  The script below does the selection using the former methodolgy
Column( "Login Date" ) << data type( numeric ) << Format( "m/d/y" );
MyList = {"HCDS", "HCDS;LENNY", "HCDS; WACKER", "HCDS; GOLDEN SAMPLE", "HCDS; ALJ", "HCDS; LENNY C",
"HCDS; WACKER; GOLDEN SAMPLE", "HCDS; WACKER; PRE-MOVE"};
dt6 << Select where( (Contains( MyList, :Site ID )) & :Analysis == "G4" );
dt6 << Select where( format(Column( "Login Date" )[Row()], "M/D/Y" ) == "01/07/2018", current selection( "extend" ) );
dt7 = dt6 << Subset( Output Table( "Aloha Lenny Assay Subset" ), Selected Rows( 1 ), Selected Columns( 0 ) );
dt7 << select where( Is Missing( :Label ID ) ) << delete rows;
selrows = dt7 << get rows where( :Formatted Entry == "ND" );
dt7:Formatted Entry[selRows] = "0";
dt7:Formatted Entry << data type( Numeric );
wjalford
Jim,
I tried your suggestion and still the data did not filter.  Below is what I used.
Regards,
Wayne
Here is a Select Where example, in the same structure as your noted Select Where.  It works.  So I believe you need to possibly use the JSL Debugger to step through your code and find out where the issue(s) is/are.
names default to here(1);
dt= open("$SAMPLE_DATA/Aircraft Incidents.jmp");
MyList = {"Accident", "Incident" };
dt << Select where( (Contains( MyList, :Investigation Type) & :Location == "Eden, UT"));
dt << Select where( format(Column( "Event Date" )[Row()], "M/D/Y" ) == "01/05/2001", current selection("extend"));
I checked out the code back to JMP 11.  The "current selection("extend")", was added in JMP 12, so the JSL does not work properly in JMP 11, but it does work after that release.
wjalford
Jim,
I am using 14.1.  I have tried so many different ways to format my dates and have not figured out the right format.  Below is more of my code.  I am passing a variable from a date box.  My excel import Login Date looks like
1/2/2019 9:11
 Please take a look if I am passing the ALstartDT correctly and any recommendation on how to properly format the date to get the select to work.
Thank you,
Wayne
Clear Log();
Names Default to Here (1);
runScript = Expr(
TempstartDT = start << get;
TempendDT = end << get;
ALstartDT = Uppercase(Format(TempstartDT, "mm/dd/yyyy"));
ALendDT = Uppercase(Format(TempendDT, "mm/dd/yyyy"));
// Written by Vince Faller
// Makes a calendar come up on a numeditbox (defaults to now)
// Note, this only works on JMP 11 or above
dateBox = Function(
{timething = Today()},
{newbox},
newbox = Eval(
Substitute(
Name Expr(
Number Edit Box(
timething, // Eval(Sub()) because of JMP quirk
10, // Just need this because JMP doesn't default a width
<<Set function(
Function( {self},
If( Is Missing( self << get ),
self << Set( Eval( DUMMY ) ) // Sets the date to the timething argument
<< Set Format(Format( "m/d/y h:m:s", 23, 0 ) ); // Makes datetime format for the box (gives calendar)
Expr( DUMMY ), timething
newbox;
nw =
New Window( "SQL Data Table Extraction",
LineUpBox(NCol(2),
TextBox("Start DateTime"), start = dateBox(Today()- InDays(12)),
TextBox("End DateTime"), end = dateBox(),
ButtonBox("Cancel", ButtonPressed = "Cancel"), ButtonBox("Get Data", ButtonPressed = "Get Data") //stores users button press input into variable
wait (15);
//If statements to take action based on which button was pressed on the date prompt
If ( ButtonPressed == "Cancel", nw << Close Window);
If ( ButtonPressed == "Cancel", Stop());
if ( ButtonPressed == "Get Data", runScript);
If ( ButtonPressed == "Get Data", runScript2);
If ( ButtonPressed == "Get Data", nw << Close Window);
Caption("Query is running");
wait(0);
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Worksheet Settings(
1,
Has Column Headers( 1 ),
Headers Start on Row( 1 ),
Data Starts on Row( 2 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 ),
Multiple Series Stack( 0 ),
Import Cell Colors( 0 ),
Limit Column Detect( 0 ),
//Column ("Login Date") << data type (numeric) << format("m/d/y");
dt6 << Select where (:Login Date >= ALstartDT,current selection("extend"));
dt7 << select where(Is Missing (:Label ID)) << delete rows;
selrows=dt7 << get rows where (:Formatted Entry == "ND");
dt7:Formatted Entry[selRows]="0";
dt7:Formatted Entry << data type(Numeric);
Because you have set your variable "ALstartDT" to a string
ALstartDT = Uppercase( Format( TempstartDT, "mm/dd/yyyy" ) );
(The Format() function returns a string value)
You then need to convert your ":Login Date" to a string also....the ":Login Date" I am assuming is a JMP Date Column.
dt6 << Select where( Format(:Login Date[row()], "mm/dd/yyyy") >= ALstartDT, current selection( "extend" ) );
wjalford
Jim,
When I try to convert :Login Date to a string, I recieve the error that argument should be numeric{1} in access or evaluation of 'Format', Format/*###*/:Login Date [Row()], "mm/dd/yyyy")
Regards,
Wayne
Oops, my error.  The [Row()] is the problem.  Use
dt << select where( Format( :Login Date, "mm/dd/yyyy" ) <= ALstartDT );
wjalford
Jim,
I still get argument should be numeric{1} in access or evaluation of 'Format' , Format/*###*/(:Login Date, "mm/dd/yyyy")
I am pretty sure the issue is a mismatch in whether or not the column is character vs. the comparison variable is character.  Can you attach a sample data table?
