AT
AT
Pivot Table
I like to transform the following attached JMP table (sample) into sample_out.
I appreciate your help. Thanks
stan_koprowski
Re: Pivot Table
Hi @AT ,
One option for accomplishing what you want is to use one of the table functions, specifically, Tables-->SplitTables-->SplitTables-->Split
And the resulting JSL script--
Data Table( "sample.jmp" ) << Split(
	Split By( :test_parameter ),
	Split( :value ),
	Sort by Column Property
cheers,
Stan
AT
AT
Re: Pivot Table
Thanks so much for quick response. I did try it and works as expected.
stan_koprowski
Re: Pivot Table
Hi @AT ,
	Split( :value ),
cheers,
Stan
AT
AT
Re: Pivot Table
