miguello
Need help with expressions, column references, formulas and column renaming
All,
Need some help in the following case.
I have a name of a column in a string format.
I need to create a new column with formula based on the old one. I do it like so:
oldCol = "OldColumn";
Eval( Eval Expr( dt << New Column( "NewColumn", formula( As Column( Expr( oldCol ) ) ) ) ) );
Then later in the script I need to rename the old column. I do it like this:
Column(oldCol) << Set Name("NewOldColumn");
The problem now is that since I have the New Column's formula in the form of:
As Column("OldColumn")
it does not update when OldColumn changes name.
I would like to have it in the form of
:OldColumn
but I don't know how to do that.
So, the question is: How do I need to modify expression:
so that it produces formula in the form of :OldColumn, and not in the form of As Column("OldColumn")?
Here is the full script to play with:
dt = New Table( "TestColumnsReferences",
	Add Rows( 3 ),
	New Column( "OldColumn", Character, "Nominal", Set Values( {"a", "b", "c"} ) )
oldCol = (dt << Get Column Names(string))[1];
//oldCol = "OldColumn";
Thanks, M.
4 ACCEPTED SOLUTIONS
Re: Need help with expressions, column references, formulas and column renaming
Here is one approach that works for me.  I have expanded the naming to handle complex JMP column names.  This confuses the reader a bit, but makes the method more powerful
	Add Rows( 3 ),
	New Column( "OldColumn+one", Character, "Nominal", Set Values( {"a", "b", "c"} ) )
oldCol = (dt << Get Column Names( string ))[1];
//Eval( Eval Expr( dt << New Column( "NewColumn", formula( As Column( Expr( oldCol ) ) ) ) ) );
Eval(
	Substitute(
			Expr(
				dt << New Column( "NewColumn", formula( __oldCol__ ) )
		Expr( __oldCol__ ), parse(":\!"" || oldCol || "\!"n")
Column( oldCol ) << Set Name( "NewOldColumn" );
miguello
Ok, I figured it out. For the formula part just use the following chain:
 Name Expr(Expr(Parse(Eval Insert(":#oldCol#", startChar="#"))))
Had to use startChar="#" since in real script formula actually uses REgEx where "^" is used.
So the full script is this:
	Add Rows( 3 ),
Eval( Eval Expr( dt << New Column( "NewColumn", formula( Name Expr(Expr(Parse(Eval Insert(":#oldCol#", startChar="#")))) ) ) ) );
This way formula has :OldColumn rather than As Column("OldColumn") and you can now safely rename columns without breaking formula.
ErraticAttack
Personally I like using the JSL Quote() function to maintain syntax highlighting and lexical parsing -- then just pass the value into the :Name() directive, as such
	Add Rows( 3 ),
Eval( Parse( Eval Insert( JSL Quote(
	dt << New Column( "NewColumn", Formula( :Name("^oldCol^") ) )
Jordan
One more option is combination of Eval(), EvalExpr(), Expr(), Name Expr() and As Column()
dt = New Table("TestColumnsReferences", Add Rows(3),
	New Column("OldColumn", Character, "Nominal", Set Values({"a", "b", "c"}))
Eval(Eval Expr(dt << New Column("NewColumn", formula(Expr(Name Expr(AsColumn(oldCol)))))));
8 REPLIES 8
miguello
I see one way of doing that (but rather not do it this way).
Get column names not as strings, but as references, and then just use Name Expr():
oldCol = (dt << Get Column Names())[1];
Eval( Eval Expr( dt << New Column( "NewColumn", formula( Name Expr( oldCol ) ) ) ) );
but I already have name of the column as a string, and would like to stick with it.
	Add Rows( 3 ),
Eval(
	Substitute(
			Expr(
miguello
Yep, essentially the same approach as I showed below, only use Substitute instead of Eval Insert, right?
miguello
Problem with "As Column" as I explained in the question is that is stays in the formula, and then when I later change name of the column that I refer to in the column (and I do change it) the formula becomes invalid
My apologies, with your combination Expr --> Name Expr --> As Column it does work! It turns As Column("string") into :string!
I've been given several solutions here, and I really liked the one with JSL Quote, but this is my new favorite. Will have to re-do the script all over again :)
miguello
	Add Rows( 3 ),
ErraticAttack
	Add Rows( 3 ),
Jordan
miguello
Thank you for the tip on JSL Quote()! It really is much cleaner now that I don't have to escape all the quotes.
