LaserGuy
Window that Scrolls Through Images in a Folder
I need some help with the scripting syntax. I am using JMP 16.
I have the script to read through all the files in a subfolder and identify the files that has the jpg extension.
What I would like to do is display a Window, with a forward and backward button, that would allow the user to display the images. How would I go about creating that?
Any help would be appreciated.
folder = char(Get Default Directory()) || "images/"; //subfolder is "images"
names = Files In Directory( folder );
dtpicnames = New Table( "Filenames of Images",
	New Column( "filename", character ),
	New Column( "inspection result", character ),
	New Column( "path", character )
dtpicnames << move window(800, 0);
for( ii = 1, ii <= N Items(names), ii++,
	if( Ends With( names[ii], ".jpg"),
		dtpicnames << Add Rows(1);
		dtpicnames:filename = names[ii];
		dtpicnames:path = folder || names[ii];
img = new image(dtpicnames:path[1]);
	img << scale(0.5);
w = New Window( "Image", pb = Picture Box( img ) );
w << move window(0, 0);
Re: Window that Scrolls Through Images in a Folder
Here is a modification of your code that works on an image folder on my system
dtpicnames << move window( 800, 0 );
For( ii = 1, ii <= N Items( names ), ii++,
	If( Ends With( Uppercase( names[ii] ), ".JPG" ),
		dtpicnames << Add Rows( 1 );
		dtpicnames:path = folder || "\" || names[ii];
theRow = 1;
img = New Image( dtpicnames:path[theRow] );
img << scale( 0.1 );
	V List Box(
		vlb = V List Box( pb = Picture Box( img ) ),
		H List Box(
			Button Box( "Up",
				If( theRow > 1,
					theRow --;
					pb << delete;
					vlb << append( pb = Picture Box( img ) )
			Button Box( "Down",
				If( theRow < N Rows( dtpicnames ) - 1,
					theRow ++;
					pb << delete;
					vlb << append( pb = Picture Box( img ) );
w << move window( 0, 0 );
theRow = 1;
	V List Box(
		H List Box(
			Button Box( "Up",
				If( theRow > 1,
					theRow --;
					pb << delete;
			Button Box( "Down",
					theRow ++;
					pb << delete;
