See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Name quote a strange column name
pauldeen
I'm trying to insert a column name into a fit model expression. For that I need to escape strange characters in column names to do that we use the :"name"n convention. So how do I go from a string column name to this format?
colListY = {"Plating Thickness (m\!"\!")"};
//This doesn't work
newcolumnref = eval insert("\[:"^colListY[1]^"n]\");
//Looking for this end result
:"Plating Thickness (m\!"\!")"n
Which I can then insert anywhere, for example:
insert into(expr(Y()), newcolumnref);
Anybody know of a robust way to do this?
Re: Name quote a strange column name
More notes:
I explicitly referenced the table in the column function. Might make a difference if multiple tables are open.
If you are concatenating strings, this might do it; you can always use the :"height"n even if not required (height, for example.)
colreftxt = ":" || Regex( Log Capture( Print( colListY[1] ) ), "^\s*(.*)\s*$", "\1" ) || "n";
write(colreftxt);
which might be escaped right. Expression manipulation will probably be easier than parsing text assembled like this.
22 REPLIES 22
You can use the Column, or As Column functions to provide protection to the complex column name
newcolumnref = eval insert("column(\!"^colListY[1]^\!")");
If you can avoid getting the name of the column as a string, and get the column object instead, it might be easier. Below, cols is a list of column objects, not their names.
dt = Open( "$sample_data/big class.jmp" );
dt:age << setname( colListY[1] );
cols = dt << getcolumnnames;// don't use the string keyword
/* {name, "Plating Thickness (m\!"\!")"n, sex, height, weight} */
script = Expr(
	Fit Model(
		Y( :weight ),
		Effects( F1 ),
		Run(
			:weight << {Plot Actual by Predicted( 1 ), Plot Residual by Predicted( 1 ),
			Plot Effect Leverage( 1 )}
Substitute Into( script, Expr( F1 ), cols[2] );
Write( Name Expr( script ) );
Fit Model(
	Y( :weight ),
	Effects( "Plating Thickness (m\!"\!")"n ),
	Run(
pauldeen
@txnelson The problem is that when building the fit model script the column() format cannot be used:
Fit Model(
	//Y( :"Plating Thickness (m\!"\!")"n ), <- works
	Y(column("Plating Thickness (m\!"\!"")), //<- does not work
	Effects(
		:"Shift-temp"n, :Position, :Subgroup, :"Shift-temp"n * :Position,
		:"Shift-temp"n * :Subgroup, :Position * :Subgroup
@Craige_Hales the users selects the columns with a Col list box() and I pass a << get items message to it. That gives me the list of column names as a string. I could locate those column names in the table and find the column number but when assembling the effects expression this method will not allow me to build the interactions as shown above.
Is there a way to do expression concatenation to go from string to col reference with name escape?
try this combination of the two answers:
script = Expr(
	Fit Model(
		Y( F1 ),
		Effects( :height ),
		Run( F1 << {Plot Actual by Predicted( 1 ), Plot Residual by Predicted( 1 ), Plot Effect Leverage( 1 )} )
Substitute Into( script, Expr( F1 ), Column( dt, colListY[1] ) );
Fit Model(
	Y( Column( "Plating Thickness (m\!"\!")" ) ),
	Effects( :height ),
	Run(
		Column( "Plating Thickness (m\!"\!")" ) << {Plot Actual by Predicted( 1 ),
Eval( script );
run with column substitutedrun with column substituted
More notes:
write(colreftxt);
pauldeen
Thanks Craige, It seems like this is more complicated than it should be but it works
For anybody trying to do this, I put Craige's solution in a function:
WrapColumns = Function({ColName},{default local},
	ReturnList = {};
	If(is list(ColName),
		For(i=1, i<=n items(ColName), i++,
			insert into(ReturnList, parse(":" || Regex( Log Capture( Print( ColName[1] ) ), "^\s*(.*)\s*$", "\1" ) || "n");)
		insert into(ReturnList, parse(":" || Regex( Log Capture( Print( ColName ) ), "^\s*(.*)\s*$", "\1" ) || "n");)
	Return(ReturnList);
It is too complicated. You can probably replace the regex() with trim() because that is all it is doing. Originally I thought it was going to remove the outer quotation marks that print() leaves behind. (edit: and there is no need to trim at all for the input to parse!)
You might have [1] where you need [i] in your example.
pauldeen
Updated with Craige's feedback, thanks for the 1/i!
	ReturnList = {};
			insert into(ReturnList, parse(":" || Log Capture( Print( ColName[i] ) ) || "n"))
		insert into(ReturnList, parse(":" || Log Capture( Print( ColName ) ) || "n"))
	Return(ReturnList);
To explain for any one watching: the print function does two things: it escapes the internal quotation marks (and other special cases) and it adds external quotation marks. That produces a valid string, and Paul's code then adds a : in front and an n afterward and parses the result into a JSL column name constant. There might, or might not, be an actual column that the column name constant can attach to when used in a script. The column does not need to exist when Paul's code runs. Without the print() function, I'm not sure what function I'd use to get the escaping done (the rules are too complicated to write my own.) Because the original name contained embedded quotation marks, it needs the escaping before being turned into a column name constant.
If the data table is open, you can use the column() function in much the same way to get a column object that (I'm pretty sure) can be used in all the same places that the column name constant can appear. That column object refers to a real column, at least until the table is closed. Launching a platform with an expired column object or a column name constant that doesn't match a table column will produce an expected error message.
@XanGregg
