tylerram93
Name Unresolved: state in access or eva
Making a GUI using SAS and loading in data from .csv files.I found this code on one of the threads, but when I load my .csv file in it shoots me this error. Below is the code:
Cheers,
Tyler
Name Unresolved: state in access or evaluation of 'state' , state/*###*/
//Call CreateBivariate to do a bivariate (two variable) analysis\
status = List(0,0);
New Window("Custom Analysis",
H List Box(
V List Box(
Panel Box("Controls",
Text Box("Choose Analysis"),
choice = Check Box({"Distribution","Bivariate"},
current = choice << Get(1);
If( And( current, Not(state[1] ) ),
dt << Append(
dt = V List Box(
dt<< Distribution( Y(:Column(14)), X(:Column(16) ) )
status[1]=1; //mark as present
If( And( Not( current ), status[1] ),
dt << Delete;
status[1]=0;
current = choice << Get(2);
bv << Append(
bv1 = V List Box(
dt<< Bivariate( Y(:Column(14)), X(:Column(16)) ) )
status[2]=1; //mark as present
If( And( Not( current ), status[2] ),
bv1 << Delete;
status[2]=0;
dt = V List Box()
Re: Name Unresolved: state in access or eva
It appears that either there is a missing list called "State" or that it is a typo and "State" should actually be "Status"
tylerram93
Name Unresolved: bv in access or evaluation of 'bv' , bv/*###*/
Changed all the states to status, but it gave me this error?
I have to admit, that I didn't do a real indepth review of the code when I made my previous response.  I stand behind my comment about State and Status, however, when I look further into the code, it doesn't seem to make much sense.  Yes it does generate a display window, with a couple of selections that can be made, but it then attemps to run a distribution using a no existant X column, and pointing to a pointer to a V List Box.    I don't think this code ever worked.
What do you expect the code to have provided you?
tylerram93
Sorry, this is my very first time using SAS. I am only experienced in Python and MATLAB. I want the code to just be able generate a distribution or bivariate analysis by clicking the box and using the .csv file I load in using:
dt = Open("C:\Users\Desktop\Data.csv");
I can do the bivariate analysis using two columns from the spreadsheet, but don't know how to incorporate it into a New Window()
Thanks for all the help!
Best,
Tyler
tylerram93
I actually got it to work. Figured out you named to add Eval( Y column) and Eval(X column).
Thanks again for the help!
Tyler
BTW, the software you are using is typically referred to as JMP software.  SAS typically refers to the larger and original software system from SAS Institute.
