Not sure the predicted range is too meaningful here, as indicated per earlier comments. You might also try Model Screening if you have JMP Pro. Also, some simple univariate analysis (in Distribution) reveals that there may be some resolution limitation in the HDD_OSA response:
Here I generated a model that predicts similarly (low R-squared for training and validation sets) but for which the SSE and -Loglikelihood of the Validation set are lower that the initially proposed model:
Also probably good to be aware of the higher correlation between Inner_EW_R2 and OW_R2.
You may benchmark this one against your Python model with RELU.
