yvesprairie
NEtCDF4 connector
Dear all,
Am I the only one having trouble with the NetCDF4 connector. It works well when the .nc file has groups but not at all when it doesn't. Is this the expected behaviour? FYI, I'm using JMP 19.2 on MAcOS.
Many thanks for any suggestions, Yves P.
Emeritus Professor
Re: NEtCDF4 connector
If this is a connector found from JMP Marketplace, make a post directly (question maybe?) to the marketplace item so the developer can see it.
@yvesprairie If you add a question on the JMP marketplace in the Q&A section of the extension the connector owner will get an email directly with your question. It also helps keep all the questions in the same place since other users may have similar questions.
https://marketplace.jmp.com/appdetails/NetCDF+Data+Connector?tab=q-and-a
