OneFunViet
New Member
Analysis Option
I had JMP data files that I need to determine what is best analysis plot or model to use. I have X-Y axis that variable that response to Z value. I want to use that best analysis model/plot to determine the behavior and response.  I include the JMP with changed of labels avoid giving away the detail of the work. Z axis that I am interesting in the thickness of materials in well.  Thank you.
0 REPLIES 0
