N categories statistics and grouping in summary tables
I would like to ask about summary tables.
I have a grouping variable and i want to use the N categories statistic to get the count for each group.
If the column I will use for the N categories statistic has a value that appears on multiple groups of the grouping variable will the N categories count include them all, once for each group or will it only keep it once, the first time it appears in any group and it will not be counted for the rest of the groups.
Hope my wording is not confusing.
Best Regards and thank you in advance
Re: N categories statistics and grouping in summary tables
I would try it on a sample case, to prove to yourself that it is working the way you want it to.
It will be counted in the N Statistic for each of the Grouping it is found in.
Good morning,
Thank you for the reply.
To make sure I understood correctly. I should choose just N instead of the N categories statistic?
I tried with few data points (used duplicates as well to make sure) and N categories:
-doesn't count duplicates (as was expected) and
-if a value appears in multiple groups, in the summary table it is counted once for every group.
So no data other than the duplicates are left out.
Thank you very much for the recommendation.
