My script editor is very slow
it is lagging behind my typing and I am not a fast typer! Does anyone have/had the problem? Is there a solution? I am working on Windows 7  (64), and my resource monitor shows some 25% CPU usage when I scroll in my scripts, which also sounds too much to me...
Ursula
Re: My script editor is very slow
Dear Jeff,
the extreme slow performance is solved: has nothing to do with JMP, only it impacted JMP much more than any of the microsoft products. It's been a miscommunication between the labtop and the docking station, solved by using another docking station, technical details were above my understanding.
Sorry for bothering, and thanks for providing help!
Kind regards,
Ursula
Jeff_Perkinson
Do you have the "Color unknown object messages" option turned on?
That option can affect script editor performance. If it's on, try turning it off and see what happens.
If that's not it, can you give us some more details on the problem?
Does the typing problem happen with an empty script editor?
How many lines is the script that is scrolling poorly? Do you have lots of JMP windows open or just the script editor?
-Jeff
-Jeff
Jeff_Perkinson
One more thing, what version of JMP are you using?
-Jeff
-Jeff
Dear Jeff,
sorry I was not answering. Got a brand new computer, hoped my problem would disappear but it persists. The color option is off, and obviously not the root cause of the problem. When typing in an empty script the lag is just as bad as with some 200 lines script.
I am working with JMP Pro 11.2.0 64 bit under MS Windows 7 Enterprise 64 bit, SP1.
Help is very welcome .
Regards,
Ursula
Dear Jeff,
Kind regards,
Ursula
