Mutidimensional scaling - data format
I am trying to conduct a multidimensional scaling procedure using a set of multivariate data.  JMP provides a sample data "Flight Distance" which contains a triangular data of distances.  In this case each distance is one value, but the data I consider is like individual distances measured several times, each being slightly different.  My actual data consists of combinations of 10 variables, the distance of each being measured 123 times.  Is it possible to calculate multidimensional scaling with JMP?  If so, what will the data table look like?
Phil_Kay
Re: Mutidimensional scaling - data format
Sorry you've not had a response yet. It would help if you can explain what questions you are trying to answer by doing this analysis.
