So the shapes that are referenced in your data table are based on the second column in the Name file, right? This is a clip from my Name file:
![Martin_0-1590164395266.png Martin_0-1590164395266.png](https://community.jmp.com/t5/image/serverpage/image-id/24133iE6433B8649A16843/image-size/medium?v=v2&px=400)
but what I have done is add 10 additional Part ID's (one for each spot within each of the 96 wells) for each Shape ID in my XY file. So for each Shape ID in the XY file, I have 11 Part ID's (10 for spots and 1 for the outer circle). My final graph looks like this:
![Martin_1-1590164672420.png Martin_1-1590164672420.png](https://community.jmp.com/t5/image/serverpage/image-id/24135i7FE6FE0049D1022D/image-size/large?v=v2&px=999)
In order to use the individual spots, instead of the outer 96 wells, how do we use the combination of Well Number and Spot Number? I thought it was with different Part ID's, but can't seem to use them.
