tourniquet
Multiple regression new variable
Hi everyone.
I want to look at my thesis model using several regressions in three steps. I know there are programs where you can do the whole model in one step, but I am not at that level.
Basically the first step is want to do a multiple regression with three IV and 1 DV. The effects of the IV's on the DV will be the new IV in a multivariate analysis, and the third step will be another muliple regression.
My question is: how do I save the restults from the first multiple regression and use it as a new variable? I am sorry if this is super basic, but I would really appreciate some help!
Re: Multiple regression new variable
I assume that you know how to make a JMP data table and enter the data. I will call the three independent variables X1-X3 and the dependent variable Y.
  1. Select Analyze > Fit Model.
  2. Select column Y and click Y.
  3. Select columns X1 through X3 and click Add.
  4. Click Run.
  5. Click the red triangle at the top left and select Save Columns > Prediction Formula.
Now you will have a new column, Pred Y in the data table. You can use it like any variable at this point.
  4. Click Run.
tourniquet
Thank you so much for taking the time to answer my newbie question. You made my day! :D
