anne_sa
How can we automatically run a script when opening a table?
Hello everyone,
I would like to know if there is a way to automatically run a script each time a table is open.
Thanks in advance for your help!
Re: How can we automatically run a script when opening a table?
I am not aware of such a feature.  However, one can create a JMP Report(.jrp) or a script(.jsl) or an addin(.jmpaddin) that when opened, would open the data table and run a script.  What are the specifics of what you are wanting to do?
You can create a table script called "On Open" which will be run when the data table is opened.
See "Prompting to Run a Script upon Opening a Data Table" in the Scripting Guide
     Help==>Books==>Scripting Guide
gzmorgan0
This works on JMP 14.
Attached are 2 files:
  • Subscribe.jsl
  • Chemical Kinetics.jmp, which is a modification of the JMP sample data table with an attached script called startup.
Run the script Subscribe.jsl then close it.  Until you unsubscribe any table you open with a script named Startup will automatically run. If you download and run the attached Chemical Kinetics.jmp table, a bivariate script named startup will automatically run.
gzmorgan0
  • Subscribe.jsl
anne_sa
Thank both of you for your answers!
Two different but really great ways to do it :)
