frankderuyck
Multiple > 3 component Mixture DOE allowing only ternary mixtures
I need to create a mixture DOE with 7 components where only ternary mixtures are allowed. There is no specific model required; goal is screening potential interesting ternary mixtures. With 7 components 35 ternary combinations are possible: is launching a 7-factor Space Filling Design and only keeping the ternary combinations an option? Or, before launching the DOE, using the disallowed 2, 4, 5, 6 and 7 factor combinations? Or starting from the 35 three-component combinations and nesting the mixture factors? Any other suggestion?
Many thanks for input!
Victor_G
Re: Multiple > 3 component Mixture DOE allowing only ternary mixtures
Hi @frankderuyck,
I don't think Space-Filling designs are a good option for high-dimensional mixture scenarii. Because of the constraint of mixture design (and dimensionality), you'll create experiments that are in the "middle" of your experimental space, and not in the corners/borders, so most (if not all) of your design points will involve all your mixture factors.
See my experiment on Space-Filling mixture designs in this post : https://www.linkedin.com/posts/victorguiller_doe-doe-datascience-activity-7350781215546699777-Ofo9
I would rather see two options to get a design for your situation :
  1. Create a Mixture design for the three first factors (12 runs by default in JMP for assumed Scheffé cubic model), and then "copy-paste" this design so that each factor has seen all the other factors in ternary mixture designs. That means you'll have to create C(12,3) = 12! / (3! (12-3)!) = 220 designs, each with 12 runs, to get the global design matching your situation. That may not be practical or feasible.
  2. A more simple option is to use the Custom design, entering the 7 mixture factors, and specifying a model with order of the terms up to 3 only (like Scheffé Cubic). Then, the generation of points will only involve mixture up to three components, and enable a more global understanding of the best ratio.
    Here is how to generate the design (Scheffé cubic model for 7 factors, 112 runs):
    DOE(
    	Custom Design,
    	{Add Response( Maximize, "Y", ., ., . ), Add Factor( Mixture, 0, 1, "X1", 0 ),
    	Add Factor( Mixture, 0, 1, "X2", 0 ), Add Factor( Mixture, 0, 1, "X3", 0 ),
    	Add Factor( Mixture, 0, 1, "X4", 0 ), Add Factor( Mixture, 0, 1, "X5", 0 ),
    	Add Factor( Mixture, 0, 1, "X6", 0 ), Add Factor( Mixture, 0, 1, "X7", 0 ),
    	Set Random Seed( 1795703354 ), Number of Starts( 35 ), Add Term( {1, 1} ),
    	Add Term( {2, 1} ), Add Term( {3, 1} ), Add Term( {4, 1} ), Add Term( {5, 1} ),
    	Add Term( {6, 1} ), Add Term( {7, 1} ), Add Term( {1, 1}, {2, 1} ),
    	Add Term( {1, 1}, {3, 1} ), Add Term( {1, 1}, {4, 1} ),
    	Add Term( {1, 1}, {5, 1} ), Add Term( {1, 1}, {6, 1} ),
    	Add Term( {1, 1}, {7, 1} ), Add Term( {2, 1}, {3, 1} ),
    	Add Term( {2, 1}, {4, 1} ), Add Term( {2, 1}, {5, 1} ),
    	Add Term( {2, 1}, {6, 1} ), Add Term( {2, 1}, {7, 1} ),
    	Add Term( {3, 1}, {4, 1} ), Add Term( {3, 1}, {5, 1} ),
    	Add Term( {3, 1}, {6, 1} ), Add Term( {3, 1}, {7, 1} ),
    	Add Term( {4, 1}, {5, 1} ), Add Term( {4, 1}, {6, 1} ),
    	Add Term( {4, 1}, {7, 1} ), Add Term( {5, 1}, {6, 1} ),
    	Add Term( {5, 1}, {7, 1} ), Add Term( {6, 1}, {7, 1} ),
    	Add Term( {1, 1}, {2, 1}, {3, 1} ), Add Term( {1, 1}, {2, 1}, {4, 1} ),
    	Add Term( {1, 1}, {2, 1}, {5, 1} ), Add Term( {1, 1}, {2, 1}, {6, 1} ),
    	Add Term( {1, 1}, {2, 1}, {7, 1} ), Add Term( {1, 1}, {3, 1}, {4, 1} ),
    	Add Term( {1, 1}, {3, 1}, {5, 1} ), Add Term( {1, 1}, {3, 1}, {6, 1} ),
    	Add Term( {1, 1}, {3, 1}, {7, 1} ), Add Term( {1, 1}, {4, 1}, {5, 1} ),
    	Add Term( {1, 1}, {4, 1}, {6, 1} ), Add Term( {1, 1}, {4, 1}, {7, 1} ),
    	Add Term( {1, 1}, {5, 1}, {6, 1} ), Add Term( {1, 1}, {5, 1}, {7, 1} ),
    	Add Term( {1, 1}, {6, 1}, {7, 1} ), Add Term( {2, 1}, {3, 1}, {4, 1} ),
    	Add Term( {2, 1}, {3, 1}, {5, 1} ), Add Term( {2, 1}, {3, 1}, {6, 1} ),
    	Add Term( {2, 1}, {3, 1}, {7, 1} ), Add Term( {2, 1}, {4, 1}, {5, 1} ),
    	Add Term( {2, 1}, {4, 1}, {6, 1} ), Add Term( {2, 1}, {4, 1}, {7, 1} ),
    	Add Term( {2, 1}, {5, 1}, {6, 1} ), Add Term( {2, 1}, {5, 1}, {7, 1} ),
    	Add Term( {2, 1}, {6, 1}, {7, 1} ), Add Term( {3, 1}, {4, 1}, {5, 1} ),
    	Add Term( {3, 1}, {4, 1}, {6, 1} ), Add Term( {3, 1}, {4, 1}, {7, 1} ),
    	Add Term( {3, 1}, {5, 1}, {6, 1} ), Add Term( {3, 1}, {5, 1}, {7, 1} ),
    	Add Term( {3, 1}, {6, 1}, {7, 1} ), Add Term( {4, 1}, {5, 1}, {6, 1} ),
    	Add Term( {4, 1}, {5, 1}, {7, 1} ), Add Term( {4, 1}, {6, 1}, {7, 1} ),
    	Add Term( {5, 1}, {6, 1}, {7, 1} ), Add Term( {1, 1}, {2, 1} ),
    	Add Term( {1, 1}, {3, 1} ), Add Term( {2, 1}, {3, 1} ),
    	Add Term( {1, 1}, {4, 1} ), Add Term( {2, 1}, {4, 1} ),
    	Add Term( {3, 1}, {4, 1} ), Add Term( {1, 1}, {5, 1} ),
    	Add Term( {2, 1}, {5, 1} ), Add Term( {3, 1}, {5, 1} ),
    	Add Term( {4, 1}, {5, 1} ), Add Term( {1, 1}, {6, 1} ),
    	Add Term( {2, 1}, {6, 1} ), Add Term( {3, 1}, {6, 1} ),
    	Add Term( {4, 1}, {6, 1} ), Add Term( {5, 1}, {6, 1} ),
    	Add Term( {1, 1}, {7, 1} ), Add Term( {2, 1}, {7, 1} ),
    	Add Term( {3, 1}, {7, 1} ), Add Term( {4, 1}, {7, 1} ),
    	Add Term( {5, 1}, {7, 1} ), Add Term( {6, 1}, {7, 1} ), Set Sample Size( 112 ),
    	Simulate Responses( 0 ), Save X Matrix( 0 ), Make Design}
If the number of runs is too high, I would recommend starting with a more simple model : with only main effects and 2-factors interactions effects, you can create a 7-factors mixture design with 50 runs. You could then augment this design if you want to investigate higher order effects.
Of course, if you have other requirements, like avoiding the corners (pure component), some disallowed combinations or the need to cover more homogeneously the mixture experimental space, you may have to use a candidate set approach by creating a dataset respecting your constraints, and then use Custom design to use your candidate set and factors as covariates.
Victor GUILLER
Victor_G
Hi @frankderuyck,
It's almost impossible to answer your question apriori.
For a model to be "strong enough" it depends on:
  • Your objective: The precision you would like to achieve, with a measurable objective like having a RMSE < threshold or MAPE < threshold (%)
  • The type of responses you're modeling and its complexity : non-linearity, strong discontinuity, etc...
  • The experimental and measurement error/"noisyness" : experimental uncertainty/variance, measurement error/variance, etc...
  • The model type you have chosen and its adequacy to the type/complexity of response
Proceeding sequentially is a good idea in any case, and even if your model is not "good enough", there are a lot of things you can do on your results and model predictions to debug your model and augment your design. Doing some error analysis could help you figure out if some area of your experimental space are systematically incorrectly predicted, or if the errors are "homogeneously" distributed.
This error analysis can then guide your augmentation strategy : augmenting in a Space Filling strategy if the errors are homogeneously distributed and the model is not fitting well on the entire design space, or a more located augmentation if the errors are located in specific area.
Hope this answer may help you,
Victor GUILLER
14 REPLIES 14
frankderuyck
An idea also is using a special Sheffé cubic model and apllying this for all 35 ternary combinations; the corner points don't need to be tested as they are the pure components. So there will be 4 x 35 = 140 runs. We would like to start with only 50 runs, what is the best selection?
Victor_G
Hi @frankderuyck,
    DOE(
    	Custom Design,
Victor GUILLER
frankderuyck
Very smart solution Victor! Guess once the best set of mixtures is found one can model output with a ML (SVM) model or use bayesian optimization for findig the optimal mixture, what approach would you prefer?
Victor_G
The simpler, the better : I think a regression model applied to this model-based mixture design should already give you some indication about which factors (and combinations) help improve the response(s). After :
  • If you want to optimize further the response(s), then you may need new datapoints to enable the estimation of higher order terms and/or better coverage of the (reduced) experimental space. Depending of your objective (optimization only, or knowledge/coverage of the experimental space), you can then continue with Bayesian Optimization, or augment the design and add new runs through a model-based (optimal designs) and/or a model-agnostic (space-filling) approach.
  • If your goal is to build a predictive model with ML, you may need to add Space-Filling design points to help the ML algorithm do a relevant interpolation in the mixture space. ML models can only be useful if they have the required data to learn from. The design points from your first stage (mixture design with model order 2 or 3) may not cover sufficiently the experimental space to provide ML models any advantage compared to the assumed regression model.
Hope this complementary answer will help you,
Victor GUILLER
frankderuyck
Suppose cfr. attached file we select 11 candidate mixtures for further investigation; there are binary 50%/50% and ternary 33%/33%/33% candidates. How to augment so a predictive ML model Y= F(xA, xB,...,xG) is possible? In our hight throughput equipment there is room for max. 50 mixtures
frankderuyck
Possibility is to narrow the ranges of each component according to their ranges in candidate set and then start a new special Sheffé model DOE. Any other suggestion?
Victor_G
Hi @frankderuyck,
Why in this candidate mixtures dataset did you remove single component experiments ?
In your initial post you were mentioning screening of mixtures, and since you have limited budget and would like to avoid complex mixture situations involving many factors, keeping the single component experiments is very informative (even if not interesting for you). It will help understand how each factor influence the response, and not only how mixture of factors influence the response. The design (and inference) space is also increased when keeping single component mixture experiments.
For your second question, it depends on how you proceed regarding keeping the single component mixture. A good option could be :
  1. Create your 50-runs mixture design with simple model (main effects + 2-factors interactions)
  2. Measure the response(s), and use the Design Space Profiler with your specification limits to restrict your experimental space so that you are in an acceptable area.
  3. In the reduced area, add points using Space Filling Augmentation, model-based augmentation (by adding more model terms, for example with a Scheffé model), or switch to Bayesian Optimization if you're interested solely about optimization. You can also use the Simulation Experiment from the Profiler at step 2 to generate new points in your design space, with an option of "Sequencing" your generated points to cover the experimental space with predefined steps. See an example here : Example of the Simulator
Hope these few suggestions will help you,
Victor GUILLER
frankderuyck
According to JMP guidelines the Design Space Profiler can't be used for Mixture experiments correct?
Victor_G
Where did you find this recommendation/guideline ? I don't see any in the documentation : Design Space Profiler & Design Space Profiler Report
Using an example dataset "Piepel" from JMP with a standard Mixture design and Design Space Profiler + Simulator, everything works fine :
Victor GUILLER
