Jamebo
Multiple data columns into 1 row
Data converted from STDF shows 2 units looped 40x times. Overall I have 80 test instances. I want to convert data from Col2 to Col27 into a single column as saved on "sanitized" sheet
Re: Multiple data columns into 1 row
Use
     Tables=>Stack
and select columns 2-27 as the Stack Columns and then click on OK
I suggest you go through the Discovering JMP document available under the Help pull down menu
Use
     Tables=>Stack
Jamebo
Appreciate the help, Jim.
Thank you as well on the Discovering JMP.
I am a newbie on JMP and the file will help a lot.
