christianguhr
Multiple File Import - Name Filter Problem and/or
Hi all,
I have a folder full of measurement data already in the .jmp format. With JSL and the Multiple File Import I'm defining a search string which only should open files with that string. Here ist what that part of my script looks like:
searchstring="202112*;*322958*";
dt_raw=Multiple File Import(
	<<Set Folder( "C:\Folder\" ),
	<<Set Show Hidden( 0 ),
	<<Set Subfolders( 0 ),
	<<Set Name Filter( searchstring ),
	<<Set Name Enable( 1 )
) << Import Data;
Unfortunately, It  opens data containing the first string OR the second string instead of the first string AND the second (what I need). Is there a way to define the search string that it opens files with the first AND second string?
Edit: The files I'm importing look like this: 202112041419_9301_007_322958_P_11217400_11217397_11217404_11217402_raw.jmp and differ in length and position of my search string from file to file.
Best, Christian
Re: Multiple File Import - Name Filter Problem and/or
I believe the search string you want to use is
searchstring="202112*322958*";
Craige_Hales
yes. There are two special characters that can be in the MFI name pattern, ? and * . The ? matches exactly one character and the * matches zero or more. To match a name like this
for 202112 followed by 322958 you might use
202112??????_*_???_322958_?_*_*_*_*_raw.jmp
if you wanted to be really really careful about what is accepted. Or, depending how variable the format is, relax it all the way down to Jim's suggestion.
Craige
Craige_Hales
Craige
christianguhr
Thanks both of you @Craige_Hales  and @txnelson. It works perfect.
Merci,
Christian
